configure virtual-network add network ports
configure virtual-network add network ports [all | portlist]
Description
Add ports that can terminate tunnels carrying VXLAN or NVGRE encapsulated traffic.
Syntax Description
add Add to existing overlay tunnel termination configuration.
network Configuration related to underlay network.
ports Select ports that can terminate tunnels carrying VXLAN or NVGRE encapsulated traffic.
all Select all ports.
portlist Lists ports to be added.
Default
N/A.
The following example adds ports 1–10 to terminate tunnels carrying VXLAN or NVGRE encapsulated traffic:
configure virtual-network add network ports 1-10
This command was first available in ExtremeXOS 21.1.
Platform Availability
This command is available on all Universal switches and stacks supported in this document.
